Ride Steer, Caster, and Camber
Branch ID: 180
Request Number: 80000180
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Wheel Ride Steer deg/m The left wheel steer angle change due to in-phase vertical deflections of the left and right wheels or:
rtod*(C(6,3)+C(6,9))/(C(3,3)+C(3,9))*1000
F3 RESULT(3) Left Ride Caster deg/m The left caster angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
rtod*(C(5,3)+C(5,9))/(C(3,3)+C(3,9))*1000
Orientation B
rtod*(-C(5,3)-C(5,9))/(C(3,3)+C(3,9))*1000
F4 RESULT(4) Left Wheel Ride Camber deg/m
The left wheel camber angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
rtod*(C(4,3)+C(4,9))/(C(3,3)+C(3,9))*1000
Orientation B:
rtod*(-C(4,3)-C(4,9))/(C(3,3)+C(3,9))*1000
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Right Wheel Ride Steer deg/m The right wheel steer angle change due to in-phase vertical deflections of the left and right wheels or:
rtod*(C(12,3)+C(12,9))/(C(9,3)+C(9,9))*1000
F7 RESULT(7) Right Ride Caster deg/m The right caster angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
rtod*(C(11,3)+C(11,9))/(C(9,3)+C(9,9))*1000
Orientation B:
rtod*(-C(11,3)-C(11,9))/(C(9,3)+C(9,9))*1000
F8 RESULT(8) Right Wheel Ride Camber deg/m The right wheel camber angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
-rtod*(C(10,3)+C(10,9))/(C(9,3)+C(9,9))*1000
Orientation B:
