Curb to Curb Diameter and Ackerman 3 and 4
Branch ID: 300
Request Number: 80000300
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Not Used Not Used Not Used
F3 RESULT(3) Not Used Not Used Not Used
F4 RESULT(4) Percent Ackerman (Method 3) % The third method of calculating percent Ackerman. Ackerman is used to quantify the amount of scrubbing occurring on the front of the vehicle during a turn assuming no rear wheel steer. A vehicle whose front wheels are parallel (the same steer angle) has 0% Ackerman. Conversely a vehicle is said to be 100% Ackerman when the lines through the left and right spindle axes intersect in the top view at a lateral line passing through the rear wheel centers. The following equation is used to calculate percent Ackerman with Method 3.
When the Vehicle is Steering Right
outer = abs((left toe-in)/rtod)
inner = abs((right toe-in)/rtod)
percent Ackerman = (wheel base)*(atan(inner)-atan(outer))*100/ ((right spindle at kingpin y)-(left spindle at kingpin y))
When the Vehicle is Steering Left
inner = abs((left toe-in)/rtod)
outer = abs((right toe-in)/rtod)
F5 Not Used Not Used Not Used Not Used
F6 RESULT(6) Curb to Curb Diameter (Method 4) m The fourth method of calculating the approximate diameter of the circle the vehicle would move around at the current steer angles assuming no rear wheel steer.
turn radius = (wheel base)*(1/tan(inner)+1/tan(outer))/2
ctoc diam = 2*sqrt(((turn radius)+track/2)^2+ (wheel base)^2)/1000
F7 RESULT(7) Percent Ackerman (Method 4) % The fourth method of calculating percent Ackerman. See F4/RESULT(4) above for an explanation of Percent Ackerman. See F6/RESULT(6) for intermediate term calculations.
alpha = atan((wheel base)/((turn radius)+track/2))
percent Ackerman = (inner-outer)*100/(atan((wheel base)/ ((turn radius)-(right spindle at kingpin))) -atan((wheel base)/((turn radius)+ (right spindle at kingpin))))
percent Ackerman = (inner-outer)*100/(atan((wheel base)/ ((turn radius)+(left spindle at kingpin))) -atan((wheel base)/((turn radius)- (left spindle at kingpin))))
F8 RESULT(8) Ackerman Deviation (Method 4) deg The fourth method of calculating Ackerman deviation. Ackerman deviation, like percent Ackerman is used to quantify the amount of scrubbing occurring on the front of the vehicle during a turn assuming no rear wheel steer. Zero Ackerman deviation means that lines through the left and right spindle axes intersect in the top view at a lateral line passing through the rear wheel centers. The following equation is used to calculate Ackerman deviation with Method 4. See F6/RESULT(6) above for intermediate term calculations.
deviation = (outer-alpha)*rtod
