FVSA Lateral and Vertical Location
Branch ID: 170
Request Number: 80000170
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Wheel FVSA Lateral Location mm The lateral distance between the left wheel center and the left wheel center front view instant center or:
length * cos(angle)
See left wheel front view swing arm length and angle calculations in BranchID 160, components 1 and 4 (in Front View Swing Arm Length and Angle).
F3 RESULT(3) Right Wheel FVSA Lateral Location mm
The lateral distance between the right wheel center and the right wheel center front view instant center or:
length * cos(angle)
See right wheel front view swing arm length and angle calculations in BranchID 160, components 2 and 5 (in Front View Swing Arm Length and Angle).
F4 RESULT(4) Average FVSA Lateral Location mm The mean of the left and right wheel front view swing arm lateral location.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Wheel FVSA Vertical Location mm
The vertical distance between the left wheel center and the left wheel center front view instant center or:
length * sin(angle)
See left wheel front view swing arm length and angle calculations in BranchID 160, F2/RESULT(2) and F5/RESULT(5) (in Front View Swing Arm Length and Angle).
F7 RESULT(7) Right Wheel FVSA Vertical Location mm
The vertical distance between the right wheel center and the right wheel center front view instant center or:
length * sin(angle)
See right wheel front view swing arm length and angle calculations in BranchID 160, F3/RESULT(3) and F6/RESULT(6) (in Front View Swing Arm Length and Angle).
F8 RESULT(8) Average FVSA Vertical Location mm The mean of the left and right wheel front view swing arm vertical location.
