Ideal Steer Angle
Branch ID: 280
Request Number: 80000280
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) 1 (X): Ideal Steer Angle deg The outside wheel steer angle required to produce a turn radius equal to the turn radius produced by the inside wheel steer angle. It is calculated with the following equations:
When the Vehicle is Steering Right
inner = (right toe-in)/rtod
turn radius = track/2-(wheel base)/tan(inner)
ideal steer angle = -atan((wheel base)/ ((turn radius)+track/2))*rtod
When the Vehicle is Steering Left
inner = -(left toe-in)/rtod
turn radius = track/2+(wheel base)/tan(inner)
F3 RESULT(3) Not Used Not Used Not Used
F4 RESULT(4) Not Used Not Used Not Used
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Not Used Not Used Not Used
F7 RESULT(7) Not Used Not Used Not Used
F8 RESULT(8) Not Used Not Used Not Used
