Lateral Force Camber
Branch ID: 90
Request Number: 80000090
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Parallel Lateral Force Camber deg/kN The left wheel camber due to parallel lateral forces on the left and right tire patches or:
1000*(C(4,2)+C(4,4)*slr+C(4,8)+C(4,10)*slr)*rtod
F3 RESULT(3) Right Parallel Lateral Force Camber deg/kN The right wheel camber due to parallel lateral forces on the left and right tire patches or:
1000*(C(10,2)+C(10,4)*slr+C(10,8)+C(10,10)*slr)*rtod
F4 RESULT(4) Average Parallel Lateral Force Camber deg/kN The mean of the left and right parallel lateral force camber.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Converging Lateral Force Camber deg/kN The left wheel camber due to converging lateral forces on the left and right tire patches or:
1000*(C(4,2)+C(4,4)*slr-C(4,8)-C(4,10)*slr)*rtod
F7 RESULT(7) Right Converging Lateral Force Camber deg/kN The right wheel center camber due to converging lateral forces on the left and right tire patches or:
1000*(C(10,2)+C(10,4)*slr-C(10,8)-C(10,10)*slr)*rtod
F8 RESULT(8) Average converging Lateral Force Camber deg/kN The mean of the left and right converging lateral force camber.
