Longitudinal Force Deflection
Branch ID: 110
Request Number: 80000110
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left WC Longitudinal Force Deflection mm/kN The left wheel center longitudinal deflection due to parallel longitudinal forces applied to the left and right wheel centers or:
(C(1,1) + C(1,7))*1000
F3 RESULT(3) Right WC Longitudinal Force Deflection   The right wheel center longitudinal deflection due to parallel longitudinal forces applied to the left and right wheel centers or:
(C(7,1) + C(7,7))*1000
F4 RESULT(4) Average WC Longitudinal Force Deflection   The mean of the left and right wheel center longitudinal force deflection.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left TP Longitudinal Force Deflection   The left wheel center longitudinal deflection due to parallel longitudinal forces applied to the left and right tire patches or:
(C(1,1) + C(1,7) - slr*(C(1,5) + C(1,11)))*1000
F7 RESULT(7) Right TP Longitudinal Force Deflection   The right wheel center longitudinal deflection due to parallel longitudinal forces applied to the left and right tire patches or:
(C(7,1) + C(7,7) - slr*(C(7,5) + C(7,11)))*1000
F8 RESULT(8) Average TP Longitudinal Force Deflection   The mean of the left and right tire patch longitudinal force deflection.
