MDL Library User's Guide
MotionView contains a comprehensive vehicle library that can be used to simulate suspension behavior and full vehicle dynamics. Most automotive vehicle suspensions can be built from the library. Suspensions not covered in the library selections can typically be built by modifying an existing library suspension. This library is the default library that is currently used by the Model and Task Wizards.
The library files are ASCII files, which are able to be modified by skilled users. Many customers maintain their own library of vehicles and standard events that match their corporate processes and methods.
