Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer)
these files in the main input deck.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Import Files Import various file types into the selected client.
Warning Messages When Loading Files
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load Files
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save Files
Save all of the data in your current session.
Export Files Export various file types from the selected client to another format.
Include Files
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
