Longitudinal Caster Compliance
Branch ID: 130
Request Number: 80000130
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) 1 (X): Left WC Longitudinal Caster Compliance deg/kN The left wheel caster change due to parallel longitudinal forces applied to the left and right wheel centers or:
(C(5,1) + C(5,7))*1000*rtod
F3 RESULT(3) 2 (Y): Right WC Longitudinal Caster Compliance deg/kN The right wheel caster change due to parallel longitudinal forces applied to the left and right wheel centers or:
(C(11,1) + C(11,7))*1000*rtod
F4 RESULT(4) 3 (Z): Average WC Longitudinal Caster Compliance deg/kN The mean of the left and right wheel center longitudinal caster compliance.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) 4 (RX): Left TP Longitudinal Caster Compliance deg/kN The left wheel caster change due to parallel longitudinal forces applied to the left and right tire patches or:
(C(5,1) + C(5,7) - slr*(C(5,5) + C(5,11)))*1000*rtod
F7 RESULT(7) 5 (RY): Right TP Longitudinal Caster Compliance deg/kN The right wheel caster change due to parallel longitudinal forces applied to the left and right tire patches or:
(C(11,1)+ C(11,7)- slr*(C(11,5)+C(11,11)))*1000*rtod
F8 RESULT(8) 6 (RZ): Average TP Longitudinal Caster Compliance deg/kN The mean of the left and right tire patch longitudinal caster compliance.
