Spindle Length and Offset
Branch ID: 270
Request Number: 80000270
Table 1.
.plt Files .abf, .mrf Files Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Spindle Length mm The true left spindle length or the distance between the left wheel center and the point on the spindle which is closest to the kingpin axis.
F3 RESULT(3) Right Spindle Length mm The true right spindle length or the distance between the right wheel center and the point on the spindle which is closest to the kingpin axis.
F4 RESULT(4) Average Spindle Length mm The mean of the left and right spindle length.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Spindle Offset mm The true left spindle offset or the minimum distance between the left spindle axis and the left kingpin axis.
F7 RESULT(7) Right Spindle Offset mm The true right spindle offset or the minimum distance between the right spindle axis and the right kingpin axis.
F8 RESULT(8) Average Spindle Offset mm The mean of the left and right spindle offset.
