Aligning Torque Steer
Branch ID: 100
Request Number: 80000100
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Parallel Aligning Torque Steer deg/100N-m The left wheel steer due to parallel aligning torques (about global Z) applied to the left and right wheels or:
1E5*(C(6,6) + C(6,12))*rtod
F3 RESULT(3) Right Parallel Aligning Torque Steer deg/100N-m The right wheel steer due to parallel aligning torques (about global Z) applied to the left and right wheels or:
1E5*(C(12,6) + C(12,12))*rtod
F4 RESULT(4) Average Parallel Aligning Torque Steer deg/100N-m The mean of the left and right parallel aligning torque steer.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Converging Aligning Torque Steer deg/100N-m The left wheel steer due to converging aligning torques (about global Z) applied to the left and right wheels or:
1E5*(C(6,6) - C(6,12))*rtod
F7 RESULT(7) Right Converging Aligning Torque Steer deg/100N-m The right wheel steer due to converging aligning torques (about global Z) applied to the left and right wheels or:
1E5*(C(12,6) - C(12,12))*rtod
F8 RESULT(8) Average Converging Aligning Torque Steer deg/100N-m The mean of the left and right converging aligning torque steer.
