Wheel Center Translational Stiffnesses
Branch ID: 50
Request Number: 80000050
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Wheel Center X Stiffness N/mm The left wheel center longitudinal stiffness or:
1/C(1,1)
F3 RESULT(3) Left Wheel Center Y Stiffness N/mm The left wheel center lateral stiffness or:
1/C(2,2)
F4 RESULT(4) Left Wheel Center Z Stiffness N/mm The left wheel center vertical stiffness or:
1/C(3,3)
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Right Wheel Center X Stiffness N/mm The right wheel center longitudinal stiffness or:
1/C(7,7)
F7 RESULT(7) Right Wheel Center Y Stiffness N/mm The right wheel center lateral stiffness or:
1/C(8,8)
F8 RESULT(8) Right Wheel Center Z Stiffness N/mm The right wheel center vertical stiffness or:
1/C(9,9)
