Anti-Lift/Squat and Acceleration Lift/Squat
Branch ID: 230
Request Number: 80000230
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Front Anti-Lift or Left Rear Anti-Squat % The resistance to lifting in a front suspension or resistance to squatting in a rear suspension due to suspension geometry during acceleration. In a suspension with 100% anti-lift/squat the moment about the side view instant center due to weight transfer is exactly offset by the moment about the side view instant center due to the acceleration force. See the following equations:
Front Suspensions Live Axles
acx = -(front drive ratio)/2
dtwt = slr*abs(2*acx)/(diff ratio)/track
aczleft = -(cg height)/2/(wheel base) - dtwt
aczright= -(cg height)/2/(wheel base) + dtwt
Orientation A:
dzfleft = acx*(C(3,1)-slr*C(3,5))+acx*(C(3,7)-slr*C(3,11))
dzfright = acx*(C(9,1)-slr*C(9,5))+acx*(C(9,7)-slr*C(9,11))
Orientation B:
dzfleft = acx*(-C(3,1)+slr*C(3,5))+acx*(-C(3,7)+slr*C(3,11))
dzfright = acx*(-C(9,1)+slr*C(9,5))+acx*(-C(9,7)+slr*C(9,11))
dzwleft = aczleft*C(3,3) + aczright*C(3,9)
dzwright = aczleft*C(9,3) + aczright*C(9,9)
left anti-lift = -100*dzfleft/dzwleft
right anti-lift = -100*dzfleft/dzwleft
Front Suspensions Fixed Differentials
Orientation A:
dzfleft = acx*C(3,1)+acx*C(3,7)
dzfright = acx*C(9,1)+acx*C(9,7)
Orientation B:
dzfleft = -acx*C(3,1)-acx*C(3,7)
dzfright = -acx*C(9,1)-acx*C(9,7)
Rear Suspensions Live Axles
acx = -(1 - front drive ratio)/2
aczleft = (cg height)/2/(wheel base) - dtwt
aczright= (cg height)/2/(wheel base) + dtwt
Orientation A:
Orientation B:
Rear Suspensions Fixed Differentials
aczright = (cg height)/2/(wheel base)
Orientation A:
Orientation B:
F3 RESULT(3) Right Front Anti-Lift or Right Rear Anti-Squat % See F2/RESULT(2) (above) for explanation and equations.
F3 RESULT(3) Average Front Anti-Lift or Rear Anti-Squat % The mean of the left and right front anti-lift or left and right rear anti-squat.
F4 RESULT(4)
Left Front Lift or
Left Rear Squat
mm/g The front suspension lift or rear suspension squat during acceleration or:
Front Suspensions
left lift = -(dzfleft+dzwleft+aczleft/(tire stiffness))*weight
Rear Suspensions
left squat = (dzfleft+dzwleft+aczleft/(tire stiffness))*weight
F5 RESULT(5) Right Front Lift or
Right Rear Squat
Front Suspensions
right lift = -(dzfright+dzwright+aczright/(tire stiffness))*weight
Rear Suspensions
right squat = (dzfright+dzwright+aczright/(tire stiffness))*weight
F6 RESULT(6) Average Front Lift or Rear Squat mm/g The mean of the left and right front lift or left and right rear squat.
