Lateral Force Deflection
Branch ID: 70
Request Number: 80000070
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Parallel Lateral Force Deflection mm/kN The left wheel center global lateral deflection due to parallel lateral forces on the left and right tire patches or:
1000*(C(2,2) + C(2,4)*slr + C(2,8) + C(2,10)*slr)
F3 RESULT(3) Right Parallel Lateral Force Deflection mm/kN The right wheel center global lateral deflection due to parallel lateral forces on the left and right tire patches or:
1000*(C(8,2) + C(8,4)*slr + C(8,8) + C(8,10)*slr)
F4 RESULT(4) Average Parallel Lateral Force Deflection mm/kN The mean of the left and right parallel lateral force deflection.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Converging Lateral Force Deflection mm/kN The left wheel center global lateral deflection due to converging lateral forces on the left and right tire patches or:
1000*(C(2,2) + C(2,4)*slr - C(2,8) - C(2,10)*slr)
F7 RESULT(7) Right Converging Lateral Force Deflection mm/kN The right wheel center global lateral deflection due to converging lateral forces on the left and right tire patches or:
1000*(C(8,2) + C(8,4)*slr - C(8,8) - C(8,10)*slr)
F8 RESULT(8) Average converging Lateral Force Deflection mm/kN The mean of the left and right converging lateral force deflection.
