Caster and Kingpin Inclination
Branch ID: 20
Request Number: 80000020
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Caster Angle deg The magnitude is the global side view angle between the left wheel kingpin axis and global vertical. The sign is positive when the kingpin axis goes towards the front of the vehicle at the bottom and towards the rear of the vehicle at the top. See Figure 1
F3 RESULT(3) Right Caster Angle deg The magnitude is the global side view angle between the right wheel kingpin axis and global vertical. The sign is positive when the kingpin axis goes towards the front of the vehicle at the bottom and towards the rear of the vehicle at the top. See Figure 1
F4 RESULT(4) Average Caster Angle deg The mean of the left and right caster angle.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Kingpin Inclination Angle deg The magnitude is the global front view angle between the left wheel kingpin axis and global vertical. The sign is positive when the kingpin axis goes outboard at the bottom and inboard at the top. See Figure 2.
F7 RESULT(7) Right Kingpin Inclination Angle deg The magnitude is the global front view angle between the right wheel kingpin axis and global vertical. The sign is positive when the kingpin axis goes outboard at the bottom and inboard at the top. See Figure 2.
F8 RESULT(8) Average Kingpin Inclination Angle deg The mean of the left and right kingpin inclination angle.
