Roll, Tread Width, Tread Change, and Track Width
Branch ID: 40
Request Number: 80000040
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Roll Angle deg The suspension roll angle and is defined as the arctan of the difference in wheel center displacements divided by the difference in wheel center y coordinates or:
atan((rdisp-ldisp)/abs(rwcy-lwcy)
The sign is positive when the right wheel is in jounce and the left wheel is in rebound as in a left turn.
F3 RESULT(3) Tread Width mm The distance between the left and right tire patch points.
F4 RESULT(4) Tread Change mm/m The change in tread width due to a change in wheel displacement and is defined:
Orientation A:
(C(8,3)+C(8,9)-C(2,3)-C(2,9)+slr*(C(10,3)+C(10,9)-C(4,3)-C(4,9)))*2000/(C(3,3)+C(3,9)+C(9,3)+C(9,9))
Orientation B:
(-C(8,3)-C(8,9)+C(2,3)+C(2,9)+slr*(-C(10,3)-C(10,9)+C(4,3)+C(4,9)))*2000/(C(3,3)+C(3,9)+C(9,3)+C(9,9))
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Track Width mm The difference in wheel center y coordinates.
F7 RESULT(7) Not Used Not Used Not Used
F8 RESULT(8) Not Used Not Used Not Used
