Virtual Caster and Kingpin Angles
Branch ID: 20330
Request Number: 80000330
The kingpin axis or steer axis on an SLA or Macpherson strut suspension is defined by two points (the upper ball joint and the lower ball joint in the SLA suspension, the upper strut mount location and the lower ball joint in the case of the Macpherson strut suspension). When the kingpin axis is not defined by two distinct points, it must be calculated virtually, using the motion of the spindle to calculate the instant axis of rotation of the knuckle. The virtual requests (numbers 50000310-50000350) use this method to calculate the kingpin axis location, and the parameters that rely on it. These requests should be used on suspensions that do not have a clearly defined kingpin axis, such as a 4 link or 5 link front independent suspension.
For the computation of the kingpin axis, the steering needs to be free (no motion) and the suspension travel needs to be locked. The lock needs to be defined in the model and will be invoked, when computing the kingpin axis automatically. Defining the lock in the model involves the definition of an array, containing the position, direction and body to lock and calling a user subroutine to pass this information to the solver. See Locking Steering and Spring Travel for details.
Table 1.
.plt File .abf, .mrf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Virtual Caster Angle deg The angle measured from the global Z axis to the left steer axis in the side view (Z-X PLANE). Virtual caster angle is positive when the top of the steer axis inclines toward the rear of the vehicle.
F3 RESULT(3) Right Virtual Caster Angle deg The angle measured from the global Z axis to the right steer axis in the side view (Z-X PLANE). Virtual caster angle is positive when the top of the steer axis inclines toward the rear of the vehicle.
F4 RESULT(4) Average Virtual Caster Angle deg The mean of the left and right virtual caster angle.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Virtual Kingpin Angle deg The angle measured from the global Z axis to the left steer axis in the side view (Z-Y PLANE). Virtual kingpin angle is positive when the top of the steer axis inclines toward the center of the vehicle.
F7 RESULT(7) Right Virtual Kingpin Angle deg The angle measured from the global Z axis to the right steer axis in the side view (Z-Y PLANE). Virtual kingpin angle is positive when the top of the steer axis inclines toward the center of the vehicle.
F8 RESULT(8) Average Virtual Kingpin Angle deg The mean of the left and right virtual kingpin angle.
