SVSA Fore/Aft and Vertical Location
Branch ID: 150
Request Number: 80000150
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Wheel SVSA Fore/Aft Location mm The longitudinal distance between the left wheel center and the left wheel center side view instant center or:
length * cos(angle)
See left wheel side view swing arm length and angle calculations in BranchID 140, F2/RESULT(2) and F5/RESULT(5) (in Side View Swing Arm Length and Angle).
F3 RESULT(3) Right Wheel SVSA Fore/Aft Location mm
The longitudinal distance between the right wheel center and the right wheel center side view instant center or:
length * cos(angle)
See right wheel side view swing arm length and angle calculations in BranchID 140, F3/RESULTS(3) and F6/RESULTS(6) (in Side View Swing Arm Length and Angle).
F4 RESULT(4) Average SVSA Fore/Aft Location mm The mean of the left and right wheel side view swing arm fore/aft location.
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Left Wheel SVSA Vertical Location mm
The vertical distance between the left wheel center and the left wheel center side view instant center or:
length * sin(angle)
See left wheel side view swing arm length and angle calculations in BranchID 140, F2/RESULTS(2) and F5/RESULTS(5) (in Side View Swing Arm Length and Angle).
F7 RESULT(7) Right Wheel SVSA Vertical Location mm
The vertical distance between the right wheel center and the right wheel center side view instant center or:
length * sin(angle)
F8 RESULT(8) Average SVSA Vertical Location mm The mean of the left and right wheel side view swing arm vertical location.
