SDF Output
A description of the SDF output in the results .plt, .mrf, and .abf files.
SDF results are reported in the following columns:
Table 1.
.plt file Request Number F1 F2 f3 f4 F5 f6 f7 f8
.mrf,.abf file RESULT(1) RESULT(2) RESULT(3) RESULT(4) RESULT(5) RESULT(6) RESULT(7) RESULT(8)
Wheel Vertical Displacement and Vertical Force 80000000 ZERO Left Wheel Vertical Displacement Right Wheel Vertical Displacement Average Wheel Vertical Displacement ZERO Left Wheel Vertical Force Right Wheel Vertical Force Average Wheel Vertical Force
Toe-in (Steer) and Camber 80000010 ZERO Left Toe In Right Toe In Average Toe In ZERO Left Camber Right Camber Average Camber
Caster and Kingpin Inclination 80000020 ZERO Left Caster Right Caster Average Caster ZERO Left Kingpin Inclination Right Kingpin Inclination Average Kingpin Inclination
Scrub Radius and Caster Trail 80000030 ZERO Left Scrub Radius Right Scrub Radius Average Scrub Radius ZERO Left Caster Trail Right Caster Trail Average Caster Trail
Roll, Tread Width, Tread Change, and Track Width 80000040 ZERO Roll Angle Tread Width Tread Change ZERO Track Width ZERO ZERO
Wheel Center Translational Stiffnesses 80000050 ZERO Left Wheel Center X Stiffness Left Wheel Center Y Stiffness Left Wheel Center Z Stiffness ZERO Right Wheel Center X Stiffness Right Wheel Center Y Stiffness Right Wheel Center Z Stiffness
Wheel Center Rotational Stiffnesses 80000060 ZERO Left Wheel Center XX Stiffness Left Wheel Center YY Stiffness Left Wheel Center ZZ Stiffness ZERO Right Wheel Center XX Stiffness Right Wheel Center YY Stiffness Right Wheel Center ZZ Stiffness
Lateral Force Deflection 80000070 ZERO Left Parallel Lateral Force Deflection Right Parallel Lateral Force Deflection Average Parallel Lateral Force Deflection ZERO Left Converging Lateral Force Deflection Right Converging Lateral Force Deflection Average Converging Lateral Force Deflection
Lateral Force Steer 80000080 ZERO Left Parallel Lateral Force Steer Right Parallel Lateral Force Steer Average Parallel Lateral Force Steer ZERO Left Converging Lateral Force Steer Right Converging Lateral Force Steer Average Converging Lateral Force Steer
Lateral Force Camber 80000090 ZERO Left Parallel Lateral Force Camber Right Parallel Lateral Force Camber Average Parallel Lateral Force Camber ZERO Left Converging Lateral Force Camber Right Converging Lateral Force Camber Average Converging Lateral Force Camber
Aligning Torque Steer 80000100 ZERO Left Parallel Aligning Torque Steer Right Parallel Aligning Torque Steer Average Parallel Aligning Torque Steer ZERO Left Converging Aligning Torque Steer Right Converging Aligning Torque Steer Average Converging Aligning Torque Steer
Longitudinal Force Deflection 80000110 ZERO Left WC Longitudinal Force Deflection Right WC Longitudinal Force Deflection Average WC Longitudinal Force Deflection ZERO Left TP Longitudinal Force Deflection Right TP Longitudinal Force Deflection Average TP Longitudinal Force Deflection
Longitudinal Compliance Steer 80000120 ZERO Left WC Longitudinal Compliance Steer Right WC Longitudinal Compliance Steer Average WC Longitudinal Compliance Steer ZERO Left TP Longitudinal Compliance Steer Right TP Longitudinal Compliance Steer Average TP Longitudinal Compliance Steer
Longitudinal Caster Compliance 80000130 ZERO Left WC Longitudinal Caster Compliance Right WC Longitudinal Caster Compliance Average WC Longitudinal Caster Compliance ZERO Left TP Longitudinal Caster Compliance Right TP Longitudinal Caster Compliance Average TP Longitudinal Caster Compliance
Side View Swing Arm Length and Angle 80000140 ZERO Left Wheel Side View Swing Arm Length Right Wheel Side View Swing Arm Length Average Side View Swing Arm Length ZERO Left Wheel Side View Swing Arm Angle Right Wheel Side View Swing Arm Angle Average Side View Swing Arm Angle
SVSA Fore/Aft and Vertical Location 80000150 ZERO Left Wheel Side View Swingarm fore/aft Location Right Wheel Side View Swingarm fore/aft Location Average Wheel Side View Swingarm fore/aft Location ZERO Left Wheel Side View Swingarm vertical Location Right Wheel Side View Swingarm vertical Location Average Wheel Side View Swingarm vertical Location
Front View Swing Arm Length and Angle 80000160 ZERO Left Wheel Front View Swing Arm Length Right Wheel Front View Swing Arm Length Average Front View Swing Arm Length ZERO Left Wheel Front View Swing Arm Angle Right Wheel Front View Swing Arm Angle Average Front View Swing Arm Length Angle
FVSA Lateral and Vertical Location 80000170 ZERO Left Front View Swing Arm lateral location Right Front View Swing Arm lateral location Average Front View Swing Arm lateral location ZERO Left Front View Swing Arm vertical location Right Front View Swing Arm vertical location Average Front View Swing Arm vertical location
Ride Steer, Caster, and Camber 80000180 ZERO Left Wheel Ride Steer Left Wheel Ride Caster Left Wheel Ride Camber ZERO Right Wheel Ride Steer Right Wheel Ride Caster Right Wheel Ride Camber
Roll Steer, Caster, and Camber 80000190 ZERO Left Wheel Roll Steer Left Wheel Roll Caster Left Wheel Roll Camber ZERO Right Wheel Roll Steer Right Wheel Roll Caster Right Wheel Roll Camber
Roll Inclination 80000200 ZERO Left Wheel Roll Inclination Right Wheel Roll Inclination Average Wheel Roll Inclination ZERO ZERO ZERO ZERO
Wheel Rate, Ride Rate, and Hop Rate 80000210 ZERO Left Wheel Rate Left Ride Rate Left Hop Rate ZERO Right Wheel Rate Right Ride Rate Right Hop Rate
Roll Rate, Tramp Rate, and Roll Center Location 80000220 ZERO Suspension Roll Rate Total Roll Rate Tramp rate ZERO Roll Center Height Roll Center Lateral Location ZERO
Anti-Lift/Squat and Acceleration Lift/Squat 80000230 ZERO Left Front Anti-lift Left Rear Anti Squat Right Front Anti-lift Right Rear Anti Squat Average Front Anti-lift / Average Rear Anti Squat ZERO Left Front lift / Left Rear Squat Right Front lift / Right Rear Squat Average Front lift / Average Rear Squat
Anti-Dive/Lift and Brake Dive/Lift 80000240 ZERO Left Front Anti-dive Left Rear Anti-lift Right Front Anti-dive Right Rear Anti-lift Average Front Anti-dive/ Average Rear Anti-lift ZERO Left Front Dive / Left Rear Lift Right Front Dive / Right Rear Lift Average Front Dive / Average Rear Lift
Tractive Force Steer and Windup 80000250 ZERO Left Tractive Force Steer Right Tractive Force Steer Average Tractive Force Steer ZERO Left Tractive Force Windup Right Tractive Force Windup Average Tractive Force Windup
Brake Steer 80000260 ZERO Left Braking Force Steer Right Braking Force Steer Average Braking Force Steer ZERO - - -
Spindle Length and Offset 80000270 ZERO Left Spindle Length Right Spindle Length Average Spindle Length ZERO Left Spindle Offset Right Spindle Offset Average Spindle Offset
Ideal Steer Angle 80000280 ZERO Ideal Steer Angle ZERO ZERO ZERO ZERO ZERO ZERO
Curb to Curb Diameter and Ackerman 1 and 2 80000290 ZERO Curb to Curb Turn Diameter-Method 1 Percent Ackerman-Method 1 Ackerman Deviation-Method 1 ZERO Curb to Curb Turn Diameter-Method 2 Percent Ackerman-Method 2 Ackerman Deviation-Method 2
Curb to Curb Diameter and Ackerman 3 and 4 80000300 ZERO ZERO ZERO Ackerman Deviation-Method 3 ZERO Curb to Curb Turn Diameter-Method 4 Percent Ackerman-Method 4 Ackerman Deviation-Method 4
Virtual Steer Axis Point 80000310 ZERO Left Virtual Kingpin X location Left Virtual Kingpin Y location Left Virtual Kingpin Z location ZERO Right Virtual Kingpin X location Right Virtual Kingpin Y location Right Virtual Kingpin Z location
Virtual Steer Axis Vector 80000320 ZERO Left Virtual Kingpin X vector component Left Virtual Kingpin Y vector component Left Virtual Kingpin Z vector component ZERO Right Virtual Kingpin X vector component Right Virtual Kingpin Y vector component Right Virtual Kingpin Z vector component
Virtual Caster and Kingpin Angles 80000330 ZERO Left Virtual Caster Angle Right Virtual Caster Angle Average Virtual Caster Angle ZERO Left Virtual Kingpin Inclination Angle Right Virtual Kingpin Inclination Angle Average Virtual Kingpin Inclination Angle
Virtual Scrub Radius and Caster Trail 80000340 ZERO Left Virtual Scrub Radius Right Virtual Scrub Radius Average Virtual Scrub Radius ZERO Left Virtual Caster Trail Right Virtual Caster Trail Average Virtual Caster Trail
Virtual Spindle Length and Offset 80000350 ZERO Left Virtual Spindle Length Right Virtual Spindle Length Average Virtual Spindle Length ZERO Left Virtual Spindle Offset Right Virtual Spindle Offset Average Virtual Spindle Offset
*By convention the MAG result is the square root of the sum of the squares of the X,Y and Z values, and the RMAG result is the square root of the sum of the squares of the RX,RY and RZ values. As a result both MAG and RMAG are meaningless values for these requests.
