Load Step: DLOAD
In the DLOAD dialog, define the *DLOAD cards on individual elements or geometry (surfaces). You can also define the DLOAD on element sets.
To open the dialog in the Load Step window, expand Distributed loads in the tree, select DLOAD, and select a load collector from the Load collector table.
Load Step: DLOAD: Define Tab
In the Define tab, define *DLOAD cards on individual elements or geometry (surfaces) as well as on element sets.
There are seven different DLOAD types available: default (Pressure), centrifugal, rotary acceleration, gravity, pressure in pipe/elbow, hydro pressure, and hydro pressure in pipe/elbow.
Only default (Pressure) type DLOAD can be created on an individual element or geometry in HyperMesh. The other types are available only for element sets.
It is recommended that you use only one type of DLOAD in a load collector in HyperMesh. If you need to use multiple types of DLOAD in the same STEP, define each type in a separate load collector and add them to the same load step.
- Elements or geometry
- Element sets
The layout of the Define tab changes, based on your selection.
Define DLOAD On: Elements or Geometry
Use the Define DLOAD on: Elements or Geometry option to define the default (pressure) type of DLOAD on individual elements or geometric surfaces.
Pressure loads created on elements have special graphical display in HyperMesh. Loads created on geometric entities such as surfaces are automatically mapped to FEA mesh on export. You can also map them using the Map Loads on Geometry button.
| Button | Action |
| Define from Pressures panel | Opens the Pressures panel to
create/update DLOAD. To create a pressure on elements, go to the create subpanel, select the elems button, pick the desired elements from the HyperMesh graphics, select nodes using the switch, pick two or three nodes from a face of a selected element, input the magnitude, and click create. To create a
pressure on geometry, go to the create subpanel, select the
surfs option from the toggle,
pick the desired geometry from the HyperMesh graphics, input the magnitude, and click
create.
注:
| Map Loads on Geometry | Opens the Loads on Geom panel to map loads on geometry to FEA
mesh entities. Click Map loads to map
all geometric loads in the current load collector to FEA entities.
注:
Define DLOAD On: Element Sets
Use the Define DLOAD on: Element sets option to define various DLOAD types on element sets.
This dialog contains a element sets menu with a list of the existing element sets. There are two types of elsets in HyperMesh: components and entity sets. The Abaqus elsets that are linked to sectional property cards, such as *SOLID SECTION and *SHELL SECTION, become components in HyperMesh. Others become entity sets. To differentiate between these two types, there is a divider line "- - - - -" in the elset list that pops up if you click the element sets menu. The elsets listed below the divider line are components.
This dialog also contains a table for data line input. The table changes depending on the DLOAD type selected. The table contains the following columns.
| Column | Description |
| Elset | The name of the element sets. Element sets are added and deleted in this column using → or ←, respectively. |
| Label | The labels of pressure load. The available labels are: P1, P2, P3, P4, P5, P6, and P. |
| Magnitude | The magnitude of the load. |
| Load Id | The ID of the load collector. |
| Label | The labels of centrifugal loads and Coriolis forces. The available labels are: CENTRIF, CENT, and CORIO. |
| Coord1 | Coordinate 1 of a point on the axis of rotation. |
| Coord2 | Coordinate 2 of a point on the axis of rotation. |
| Coord3 | Coordinate 3 of a point on the axis of rotation. |
| DirCos1 | 1-component of the direction cosine of the axis of rotation. |
| DirCos2 | 2-component of the direction cosine of the axis of rotation. |
| DirCos3 | 3-component of the direction cosine of the axis of rotation. |
| Label | The labels of the DLOAD type. The available labels are: ROTA. |
| Coord1 | Coordinate 1 of a point on the axis of rotary acceleration. |
| Coord2 | Coordinate 2 of a point on the axis of rotary acceleration. |
| Coord3 | Coordinate 3 of a point on the axis of rotary acceleration. |
| DirCos1 | 1-component of the direction cosine of the axis of rotary acceleration. |
| DirCos2 | 2-component of the direction cosine of the axis of rotary acceleration. |
| DirCos3 | 3-component of the direction cosine of the axis of rotary acceleration. |
| Label | The labels of the DLOAD type. The available labels are: GRAV. |
| Comp1 | 1-component of the gravity vector. |
| Comp2 | 2-component of the gravity vector. |
| Comp3 | 3-component of the gravity vector. |
| Label | The labels of the pressure in pipe/elbow elements. The available labels are: PE, PI, PENU, and PINU. |
| Diameter | The effective inner or outer diameter. |
| Condition | The end loading condition: CLOSE (default) or OPEN. |
| Label | The labels of the hydrostatic pressure. The available labels are: HP. |
| Zero press | Z-coordinate of zero pressure level in three-dimensional or axisymmetric cases; Y-coordinate of zero pressure level in two-dimensional cases. |
| Press point | Z-coordinate of the point at which the pressure is defined in three-dimensional or axisymmetric cases; Y-coordinate of the point at which the pressure is defined in two-dimensional cases. |
| Label | The labels of the hydrostatic pressure in pipe.elbow elements. The available labels are: HPE, and HPI. |
| Button | Action |
| Review Set | Reviews the selected node sets by highlighting them in the HyperMesh graphics. Right-click Review to clear the review selections. |
| Create/Edit Set.. | Opens the Entity Sets panel in HyperMesh. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the element set list. |
| Display/Review from panel | Opens the appropriate HyperMesh panel. Use the review button to expand the loads and constraints on the sets for visualization purposes. |
| → | Add the selected node set from the drop-down menu to the data line table on the right. |
| ← | Delete the selected node set from the data line table. |
| Show Faces | This option is only shown for Default
(pressure) type. It is mainly used to review the face
identifiers of elements in the selected set. It creates a
temporary skin of the selected elset, opens the Element Selector
panel, from which you can select face elements from this skin.
When you return from the element selector panel, the selected
faces display color-coded face identifier tags. In performance
graphics, these tags are sometimes blocked by the solid mesh.
You may need to rotate the model a little to view the
tags. Right-click the Show faces button to clear the face review. |
| Define by vector | This option is only shown for Gravity type. It opens the HyperMesh vector selector panel. Pick a vector and click proceed. This vector is used to define the Comp1, Comp2, Comp3, and Magnitude of the gravity load for the selected element set. |
| Create/Edit vector.. | This option is only shown for Gravity type. Opens the Vectors panel in HyperMesh. When you finish creating/editing the vector, click return. |
| Review | Creates special review forces or moments in HyperMesh graphics for the selected node set. These review forces or moments take into consideration the *TRANSFORM cards that may be associated with nodes in the node set. Right-click Review to clear the special review loads and highlighting. |
| Update | Updates the HyperMesh database with the data lines defined in the table. By default, HyperMesh does not create a display for loads defined with sets. |
For tips on entering information and navigating in the Define tab, see Step Manager Tab Environment.
Load Step: DLOAD: Delete Tab
In the Delete tab, delete *DLOAD and other loads.
| Option | Description |
| All loads in current collector | The Delete button deletes all the loads from the current load collector. |
| All 'Distributed loads' in current collector | The Delete button deletes all distributed (*DLOAD, *FILM) loads from the current load collector. |
| By selection | The Pick Loads button opens the HyperMesh
load selector panel. Pick the loads you want to delete and click
proceed. The corresponding Reset button resets the selected loads. The Delete button deletes the selected loads. |
Load Step: DLOAD: Parameter Tab
In the Parameter tab, define optional parameters for the *DLOAD card.
The supported parameters include: Amplitude, OP, Load Case, Cyclic Mode, and Region Type.
Click Update to activate the optional parameter selection in the HyperMesh database.
