Abaqus Step Manager Overview
Use the Step Manager to create, edit and review supported keywords.
To access this tool, load the Abaqus user profile and
select Step Manager from the ユーティリティメニュー. Use the Step Manager to create, edit, and review
the following keywords in HyperMesh begins in the Step tab:
- Analysis types:
- *BUCKLE
- *DYNAMIC
- *FREQUENCY
- *HEAT TRANSFER
- *MODAL DYNAMIC
- *STATIC
- *STEADY STATE DYNAMICS
- Loads:
- *BOUNDARY
- *CLOAD
- *DLOAD
- *DSLOAD
- *FILM
- *CFILM
- *SFILM
- *TEMPERATURE
- *INERTIA RELIEF
- *INITIAL CONDITIONS {TYPE=TEMPERATURE, VELOCITY}
- Output requests:
- *OUTPUT
- *NODE OUTPUT
- *ELEMENT OUTPUT
- *STEP OUTPUT
- *ENERGY OUTPUT
- *NODE FILE
- *EL FILE
- *STEP FILE
- *ENERGY FILE
- *NODE PRINT
- *EL PRINT
- *STEP PRINT
- *ENERGY PRINT
- Interface controls:
- *MODEL CHANGE
- *CONTACT INTERFERENCE
- *CHANGE FRICTION
- *CLEARANCE
- *CONTACT CONTROLS
- Others:
- *MONITOR
- *FILE FORMAT
- *RESTART
- *STEP
