When you run the Convert to Special 2nd Order macro, a mesh matching is used to remove the mid-side nodes at the shared
edges between these first and second order elements.
Manage existing contact pairs and surface elements, and create new contact pairs and ANSYS thermal and structural surface elements using the Ansys Surface Manager.
The LS-DYNAユーティリティメニュー contains shortcuts and tools that can help simplify LS-DYNA tasks. Set the user profile from the User Profiles option of the Preferences menu.
The ユーティリティメニュー for the OptiStruct user profile contains, in addition to the default ユーティリティメニューs, three pages (Summary, FEA and Opti) of specific utilities for OptiStruct.
ANSYS Section Macro
The Section macro creates and defines section cards for beam and shell sections.
ANSYS Real Sets Macro
The Real Sets macro creates property カードイメージs for all elements that the ANSYS interface supports.
ANSYS ET Type Macro
The ET Type macro creates HyperMeshカードイメージs for ANSYS element types.
ANSYS Convert to Special 2nd Order Macro
When you run the Convert to Special 2nd Order macro, a mesh matching is used to remove the mid-side nodes at the shared edges between these first and second order elements.
ANSYS Surface Manager
