HMIN_element_writerigidlinkheader()
Writes a rigid link header to HyperMesh.
void HMIN_element_writerigidlinkheader(HM_entityidtype id, char elementtype, int dofs, HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
dofs
The degrees of freedom associated with the element.
collectorid
The ID of the collector where the rigid link element should be placed.
Call HMIN_element_writerigidlinknode() immediately after HMIN_element_writerigidlinkheader() to add the independent node and dependent nodes to the element.
None.
