blocks
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes a block to HyperMesh.
Assigns a cell to a wall ID in a block.
Assigns a value to each division.
Assigns a system to a HyperMesh block.
Writes the walls of a block to HyperMesh.
Writes a block to HyperMesh for use with interfaces and loadsteps (instead of finite difference blocks).
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
