HMIN_block_writedivision()
Assigns a value to each division.
void HMIN_block_writedivision(int divindex, double cord);
HyperMesh hminlib Function
divindex
The coordinate of the division to be assigned a value. Use:
0 When the value being assigned is in an x division.
1 When the value being assigned is in a y division.
2 When the value being assigned is in a z division.
cord
The value to be assigned to the division.
A wall must exist (HMIN_block_write()).
None.
