nodes
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Associates a node to a surface.
Sends all the nodes stored in the buffer to HyperMesh.
Frees the memory associated with nodes stored with HMIN_node_store().
Retrieves the first pointer to a node.
Retrieves the next pointer to a node.
Retrieves the pointer to a node.
Sets up a buffer to provide a work area for nodes before transferring them to HyperMesh.
Writes a node to HyperMesh.
Writes a node, accessed by the pointer to the node, to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
