Undocumented hminlib Functions
The list of undocumented hminlib functions.
HMIN_accelerometer_end()
HMIN_accelerometer_start()
HMIN_alefsiprojection_end()
HMIN_alefsiprojection_start()
HMIN_alereferencesystemcurve_end()
HMIN_alereferencesystemcurve_start()
HMIN_alereferencesystemgroup_end()
HMIN_alereferencesystemgroup_start()
HMIN_alereferencesystemnode_end()
HMIN_alereferencesystemnode_start()
HMIN_alereferencesystemswitch_end()
HMIN_alereferencesystemswitch_start()
HMIN_alesmoothing_end()
HMIN_alesmoothing_start()
HMIN_aletanktest_end()
HMIN_aletanktest_start()
HMIN_assignproperty()
HMIN_attachment_end()
HMIN_attachment_start()
HMIN_attachmentcontrol_end()
HMIN_attachmentcontrol_start()
HMIN_beamsectcol_write()
HMIN_beamsection_write()
HMIN_beamsection_writeresults()
HMIN_beamsection_writeshell()
HMIN_beamsection_writeshell_data()
HMIN_beamsection_writeshell_equation()
HMIN_beamsection_writeshell_part()
HMIN_beamsection_writesolid()
HMIN_beamsection_writestandard()
HMIN_bodie_end()
HMIN_bodie_start()
HMIN_check_readincludes()
HMIN_checkentity()
HMIN_collection_end()
HMIN_collection_start()
HMIN_collision_end()
HMIN_collision_start()
HMIN_color_convert16to64()
HMIN_comment_end()
HMIN_comment_start()
HMIN_configuration_end()
HMIN_configuration_start()
HMIN_connectorgroup_end()
HMIN_connectorgroup_start()
HMIN_connectorset_end()
HMIN_connectorset_start()
HMIN_constrainedextranode_end()
HMIN_constrainedextranode_start()
HMIN_constrainedrigidbodie_end()
HMIN_constrainedrigidbodie_start()
HMIN_constraint_end()
HMIN_constraint_start()
HMIN_contactbehavior_end()
HMIN_contactbehavior_start()
HMIN_contactgroup_end()
HMIN_contactgroup_start()
HMIN_crosssection_end()
HMIN_crosssection_start()
HMIN_damping_end()
HMIN_damping_start()
HMIN_ddval_write()
HMIN_deleteloadsinloadcols()
HMIN_deleteunusedentity()
HMIN_designpoint_end()
HMIN_designpoint_start()
HMIN_designpointmethod_end()
HMIN_designpointmethod_start()
HMIN_designpointset_end()
HMIN_designpointset_start()
HMIN_designvar_setpropertyidpool()
HMIN_designvar_writeproperty()
HMIN_designvar_writevector()
HMIN_directmatrixinput_end()
HMIN_directmatrixinput_start()
HMIN_dobjref_write()
HMIN_domain_write()
HMIN_domainids_write()
HMIN_dvprel_setpropertyidpool()
HMIN_dyload_close()
HMIN_element_solver_writexelem()
HMIN_element_writeice()
HMIN_element_writerigidlinkwithsetid()
HMIN_elementcluster_end()
HMIN_elementcluster_start()
HMIN_encryption_end()
HMIN_encryption_start()
HMIN_end_face()
HMIN_equation_write_withdoublecoeff()
HMIN_exploration_start()
HMIN_exploration_end()
HMIN_failure_end()
HMIN_failure_start()
HMIN_feature_end()
HMIN_feature_start()
HMIN_field_end()
HMIN_field_start()
HMIN_FileIsBinary()
HMIN_formulaset_write()
HMIN_formulaset_write_all()
HMIN_formulaset_write_list()
HMIN_formulaset_write_range()
HMIN_formulaset_write_rangewithexcept()
HMIN_freebodygroup_end()
HMIN_freebodygroup_start()
HMIN_freebodysection_end()
HMIN_freebodysection_start()
HMIN_friction_end()
HMIN_friction_start()
HMIN_geometricrepresentation_end()
HMIN_geometricrepresentation_start()
HMIN_handle_write()
HMIN_handleids_write()
HMIN_hourglas_end()
HMIN_hourglas_start()
HMIN_hypercube_write()
HMIN_idpool_write()
HMIN_include_define()
HMIN_include_setcurrent()
HMIN_initialize()
HMIN_interfacecomponent_end()
HMIN_interfacecomponent_start()
HMIN_interfacelinking_end()
HMIN_interfacelinking_start()
HMIN_joint_end()
HMIN_joint_start()
HMIN_list_end()
HMIN_list_start()
HMIN_load_end()
HMIN_load_start()
HMIN_load_writeacceleration_curve()
HMIN_load_writeconstraint_curve()
HMIN_load_writeflux_curve()
HMIN_load_writeforce_curve()
HMIN_load_writemoment_curve()
HMIN_load_writepressure_face_curve()
HMIN_load_writepressure_nodes_change_magnitude()
HMIN_load_writepressure_nodes_curve()
HMIN_load_writepressure_nodes_curve_change_magnitude()
HMIN_load_writetemperature_curve()
HMIN_load_writetraction_face_curve()
HMIN_load_writetraction_nodes_curve()
HMIN_load_writevelocity_curve()
HMIN_loadstep_write_group_id()
HMIN_loadstep_write_ob_id()
HMIN_locationunit_stop_write()
HMIN_locationwrite_end()
HMIN_locationwrite_start()
HMIN_MarkAlreadyCleaned()
HMIN_MarkLoopDirectionImplied()
HMIN_MarkSurfaceFailure()
HMIN_mass_end()
HMIN_mass_start()
HMIN_material_write_color()
HMIN_material_write_conditional()
HMIN_mechanism_end()
HMIN_mechanism_start()
HMIN_mergeduplicateentity()
HMIN_meshcontrol_end()
HMIN_meshcontrol_start()
HMIN_module_write()
HMIN_node_getsize()
HMIN_node_tmp_write()
HMIN_optiresponse_setpropertyidpool()
HMIN_outputblock_subentity_currentidpool()
HMIN_outputrequest_end()
HMIN_outputrequest_start()
HMIN_overwriteloads()
HMIN_panel_end()
HMIN_panel_start()
HMIN_parameter_end()
HMIN_parameter_start()
HMIN_partset_end()
HMIN_partset_start()
HMIN_physicalquantity_end()
HMIN_physicalquantity_start()
HMIN_plot_writemode()
HMIN_position_end()
HMIN_position_start()
HMIN_pretensioner_end()
HMIN_pretensioner_start()
HMIN_primitive_end()
HMIN_primitive_start()
HMIN_property_write_color()
HMIN_region_end()
HMIN_region_start()
HMIN_response_end()
HMIN_response_start()
HMIN_result_end()
HMIN_result_start()
HMIN_retractor_end()
HMIN_retractor_start()
HMIN_rigidbodie_end()
HMIN_rigidbodie_start()
HMIN_rigidwall_writegeometry_parallel()
HMIN_seatbelt_end()
HMIN_seatbelt_start()
HMIN_seatbeltcontrolpoint_end()
HMIN_seatbeltcontrolpoint_start()
HMIN_sequence_end()
HMIN_sequence_start()
HMIN_set_currentidpool()
HMIN_set_shadowsubmodelid()
HMIN_set_subentity_currentidpool()
HMIN_set_write_ordered()
HMIN_set_write_rigidlinkid()
HMIN_SetCurrentIdPool()
HMIN_setinputfileversion()
HMIN_setparameterid()
HMIN_setparameterid_dataname()
HMIN_setpropertyonentity()
HMIN_settmpfilename()
HMIN_shape3d_end()
HMIN_shape3d_start()
HMIN_shape_write()
HMIN_shape_write_color()
HMIN_signal_premature_end()
HMIN_slipring_end()
HMIN_slipring_start()
HMIN_solid_write()
HMIN_solvermasse_end()
HMIN_solvermasse_start()
HMIN_solver_beamsection_write()
HMIN_solver_beamsection_writestandard()
HMIN_solver_contactsurf_write()
HMIN_solver_controlvol_write()
HMIN_solver_domain_write()
HMIN_solver_formulaset_write()
HMIN_solver_formulaset_write_list()
HMIN_solver_load_writeacceleration_curve()
HMIN_solver_load_writeconstraint_curve()
HMIN_solver_load_writepressure_face()
HMIN_solver_load_writepressure_face_curve()
HMIN_solver_load_writepressure_nodes()
HMIN_solver_load_writepressure_nodes_change_magnitude()
HMIN_solver_load_writepressure_nodes_curve()
HMIN_solver_load_writepressure_nodes_curve_change_magnitude()
HMIN_solver_load_writetraction_face()
HMIN_solver_load_writetraction_face_curve()
HMIN_solver_load_writetraction_nodes_curve()
HMIN_solver_load_writevelocity_curve()
HMIN_solver_outputblock_write()
HMIN_solver_set_write()
HMIN_solver_set_write_ordered()
HMIN_solver_set_write_rigidlinkid()
HMIN_solver_set_write_support()
HMIN_solversubmodel_end()
HMIN_solversubmodel_start()
HMIN_start_face()
HMIN_structuralproperty_end()
HMIN_structuralproperty_start()
HMIN_studie_end()
HMIN_studie_start()
HMIN_submodel_write_Offset_ids()
HMIN_subsystem_end()
HMIN_subsystem_start()
HMIN_subsystemconfiguration_end()
HMIN_subsystemconfiguration_start()
HMIN_subsystemset_end()
HMIN_subsystemset_start()
HMIN_symmetry_write()
HMIN_symmetrypivot_end()
HMIN_symmetrypivot_start()
HMIN_system_write_refsystem()
HMIN_timestepcontrol_end()
HMIN_timestepcontrol_start()
HMIN_transformation_end()
HMIN_transformation_start()
HMIN_unsupported_card_write()
HMIN_weldline_end()
HMIN_weldline_start()
HMIN_write_solverid()
HMIN_writeattribute_boolean()
HMIN_writeattribute_char()
HMIN_writeattribute_couple_double()
HMIN_writeattribute_couple_double_array()
HMIN_writeattribute_couple_int()
HMIN_writeattribute_nodeonelement()
HMIN_writeattribute_solver_entity()
HMIN_writeattribute_solver_entity_array()
HMIN_writeattribute_solver_entity_array2d()
HMIN_writeattribute_triple_double()
HMIN_writeattribute_triple_double_array()
HMIN_writeattribute_triple_int()
HMIN_writeattribute_unsigned_char()
HMIN_writeattribute_unsigned_int()
HMIN_writeattribute_unsigned_int_array()
HMIN_writeattribute_unsigned_int_array2d()
HMIN_writeconnectordata()
HMIN_writefreepoint()
HMIN_writegeomdata()
HMIN_writeline()
HMIN_writelinesat()
HMIN_writelocationunit_entity_0D()
HMIN_writelocationunit_entity_1D()
HMIN_writelocationunit_entity_face_or_edge_id_0D()
HMIN_writelocationunit_entity_face_or_edge_id_1D()
HMIN_writelocationunit_entity_face_or_edge_node_0D()
HMIN_writelocationunit_entity_face_or_edge_node_1D()
HMIN_writesurfsat()
HMIN_writevalue_0D()
HMIN_writevalue_1D()
HMIN_writevalue_2D()
HMIN_writevalue_boolean()
HMIN_writevalue_char()
HMIN_writevalue_couple_double()
HMIN_writevalue_couple_double_array()
HMIN_writevalue_couple_int()
HMIN_writevalue_double()
HMIN_writevalue_double_array()
HMIN_writevalue_double_array2d()
HMIN_writevalue_entity()
HMIN_writevalue_entity_array()
HMIN_writevalue_entity_array2d()
HMIN_writevalue_float()
HMIN_writevalue_formula()
HMIN_writevalue_formula_color()
HMIN_writevalue_formula_list()
HMIN_writevalue_formula_name()
HMIN_writevalue_formula_range()
HMIN_writevalue_formulalistsize()
HMIN_writevalue_int()
HMIN_writevalue_int_array()
HMIN_writevalue_int_array2d()
HMIN_writevalue_long()
HMIN_writevalue_qualifier()
HMIN_writevalue_qualifier_name()
HMIN_writevalue_qualifierlistsize()
HMIN_writevalue_short()
HMIN_writevalue_solver_entity()
HMIN_writevalue_solver_entity_array()
HMIN_writevalue_solver_entity_array2d()
HMIN_writevalue_string()
HMIN_writevalue_string_array()
HMIN_writevalue_triple_double()
HMIN_writevalue_triple_double_array()
HMIN_writevalue_triple_int()
HMIN_writevalue_unsigned_char()
HMIN_writevalue_unsigned_int()
HMIN_writevalue_unsigned_int_array()
HMIN_writevalue_unsigned_int_array2d()
HMIN_writevalue_unsigned_long()
HMIN_writevalue_unsigned_short()
HMIN_writevalue_write_all()
initializeglobalsystem()
