groups
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes groups to HyperMesh.
Sends the size of the master box of a group to HyperMesh.
Sends a component ID to a group's master component list.
Writes contactsurf entity as part of group entity master definition.
Writes the master definition of a group to HyperMesh.
Sends a set’s ID to a group's master set list.
Sends the size of a slave box of a group to HyperMesh.
Sends a component ID to a group's slave component list.
Writes contactsurf entity as part of group entity slave definition.
Writes the slave definition of a group to HyperMesh.
Sends a set’s ID to a group's slave set list.
Writes a basic rigid wall to HyperMesh.
Writes a MADYMO coupling definition of a rigid wall.
Writes a cylinder definition of a rigid wall.
Writes a planar definition of a rigid wall.
Writes a prism definition of a rigid wall.
Writes a sphere definition of a rigid wall.
Writes a motion definition of a rigid wall.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
