HMIN_equation_write()
Writes an equation to HyperMesh.
void HMIN_equation_write(HM_entityidtype id, char type, float* constant, int Inode_len, HM_entityidtype *Inodes, int *Idofs, float *Icoeffs, HM_entityidtype Dnode, int Ddof, float* Dcoeff, HM_entityidtype loadcollectorid);
HyperMesh hminlib Function
id
The ID of the equation.
equationtype
The type of the equation, a user-defined value.
constant
The constant of the equation.
Inode_len
The number of independent nodes.
Inodes
The IDs of the independent nodes.
Idofs
The degrees of freedom associated with the independent nodes in the form (123456 or 135).
Icoeffs
The coefficients associated with the independent nodes (6 per node).
Dnode
Ddof
The degree of freedom associated with the dependent node (may be set to 0).
Dcoeff
The coefficient associated with the dependent node (may be set to 0).
loadcollectorid
The collector where the equation should be placed.
None.
