attributes
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Transfers a double attribute to HyperMesh.
Transfers a double array attribute to HyperMesh.
Transfers a 2-D double array to HyperMesh.
Transfers an entity attribute to HyperMesh.
Transfers an entity array attribute to HyperMesh.
Transfers a 2-D entity array attribute to HyperMesh.
Transfer an integer attribute to HyperMesh.
Transfer an integer array attribute to HyperMesh.
Transfer a 2-D integer array to HyperMesh.
Transfer a string attribute to HyperMesh.
Transfer a string array attribute to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
