hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes an assembly to HyperMesh.
Transfers subassemblies of an assembly to HyperMesh.
Transfers the components of an assembly to HyperMesh.
Specifies whether to create an assembly structure matching the include file structure during import.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
