HMIN_rigidwall_writegeometry_prism()
Writes a prism definition of a rigid wall.
HMIN_rigidwall_writegeometry_prism(HM_entityidtype id, unsigned char finite, double xaxisx, double xaxisy, double xaxisz, double lengthx, double lengthy, double lengthz)
HyperMesh hminlib Function
id
The ID of the rigid wall.
finite
A flag for finite geometry.
xaxisx, xaxisy, xaxisz
The x, y, z locations used to calculate the local x axis.
lengthx, lengthy lengthz
The local x, y and z length of the rigid wall.
This command must be preceded by the HMIN_rigidwall_write() command. The ID must refer to an existing rigid wall.
xaxisx, xaxisy, and xaxisz relate to the base values of the rigid wall in the same way as normalx, normaly, and normalz relate to the base in HMIN_rigidwall_write().
None.
