HMIN_group_write()
Writes groups to HyperMesh.
void HMIN_group_write(HM_entityidtype id, char * name, int config, int type, HM_entityidtype materialid, int color, int masterdefinition, int slavedefinition);
HyperMesh hminlib Function
id
The ID of the group.
name
The name of the group.
config
The configuration assigned to the group.
type
The type assigned to the group.
materialid
The ID of the material associated with the group.
color
The color assigned to the group.
masterdefinition
The method being used to define the master surface. Set to 0 for entity, 1 for comps, 2 for box, 3 for all, 4 for sets, or 5 for contact surfs.
slavedefinition
The method being used to define the slave surface. Set to 0 for entity, 1 for comps, 2 for box, 3 for all, 4 for sets, or 5 for contact surfs.
None.
