HMIN_rigidwall_write()
Writes a basic rigid wall to HyperMesh.
HMIN_rigidwall_write(HM_entityidtype id, double basex, double basey,double basez,double normalx,double normaly, double normalz);
HyperMesh hminlib Function
id
The ID of the rigid wall.
basex, basey, basez
(x, y, z) locations of base node.
normalx, normaly, normalz
(x, y, z) locations used to calculate the vector for the rigid wall.
This command must be preceded by a HMIN_group_write() command with the same ID.
normalx should be equivalent to basex + i ^ , normaly should be equivalent to basey + j ^ , and normalz should be equivalent to basek + k ^ . This function was designed to be passed the values from the LS-DYNA3D *RIGIDWALL card without the values being modified.
None.
