HMIN_rigidwall_writegeometry_cylinder()
Writes a MADYMO coupling definition of a rigid wall.
HMIN_rigidwall_writegeometry_cylinder(HM_entityidtype id, double radius, double lengthz)
HyperMesh hminlib Function
id
The ID of the rigid wall.
radius
The radius of the cylinder.
lengthz
The length of the cylinder.
This command must be preceded by a HMIN_rigidwall_write() command. The ID must refer to an existing rigid wall.
None.
