HMIN_node_store()
Sets up a buffer to provide a work area for nodes before transferring them to HyperMesh.
void HMIN_node_store(HM_entityidtype id, int attributes, double cords[3], HM_entityidtype superid, HM_entityidtype systemid, HM_entityidtype outputsystemid, HM_entityidtype surfaceid, int surfaceindex);
HyperMesh hminlib Function
id
The ID of the node.
attributes
User-assigned value given the node.
cords[3]
The coordinates of the node.
superid
The ID of the super element of the node.
systemid
The ID of the system in which the node is built.
outputsystemid
The ID of the analysis system of the node.
surfaceid
The ID of the surface.
surfaceindex
The index value that identifies an entity within a surface.
None.
