HMIN_block_write()
Writes a block to HyperMesh.
void HMIN_block_write(HM_entityidtype id, char * name, int color, double minimum[3], double maximum[3], int divisions[3]);
HyperMesh hminlib Function
id
The ID of the block to be written.
name
The name of the block.
color
The color of the block.
minimum[3]
The minimum values of the x, y, and z coordinates in the block.
maximum[3]
The number of divisions on the block for x, y, and z.
None.
