HMIN_element_writehex20()
Writes a twenty-noded brick solid element to HyperMesh.
void HMIN_element_writehex20(HM_entityidtype id, char elementtype, HM_entityidtype nodes[], HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
nodes[20]
The nodes associated with the element.
collectorid
The ID of the collector where the hex20 element should be placed.
None.
