HMIN_element_solver_writebar3_znode()
Writes a bar element with property idpool to HyperMesh using a node to define the local bar z axis.
void HMIN_element_writebar_znode (HM_entityidtype id, char elementtype, HM_entityidtype propertyid, HM_entityidtype node, double offseta[3], double offsetb[3], int pinsa, int pinsb, HM_entityidtype nodes[], HM_entityidtype collectorid, int propsidpool)
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
propertyid
The ID of the property to which the bar element should point.
node
The node that lies on the beam local y axis.
offseta[3]
The amount to offset the bar at end a.
offsetb[3]
The amount to offset the bar at end b.
pinsa
The degrees of freedom assigned to end a.
pinsb
The degrees of freedom assigned to end b.
nodes[3]
The nodes associated with the element.
collectorid
The ID of the collector where the bar element should be placed.
propsidpool
ID pool number of the property to which the element should point.
None.
