HMIN_element_solver_writegap()
Writes a gap element with property idpool to HyperMesh.
void HMIN_element_solver_writegap(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, HM_entityidtype nodes[], int collectorid, HM_entityidtype vectorid, int propsidpool)
HyperMesh hminlib Function
id
ID of the element.
elementtype
Type of the element.
propertyid
The ID of the property to which the gap element should point.
nodes
The nodes associated with the element.
collectorid
The ID of the collector where the gap element should be placed.
vectored
The ID of the vector associated with the element.
propsidepool
ID pool number of the property to which the element should point.
None.
