HMIN_element_writerigidlink()
Writes a rigid link element to HyperMesh.
void HMIN_element_writerigidlink(HM_entityidtype id, char elementtype, HM_entityidtype Inode, int dofs, int Dnode_len, HM_entityidtype *Dnodes, HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
Inode
The ID of the independent node.
dofs
The degrees of freedom associated with the element.
Dnode_len
The number of dependent nodes.
Dnodes
An array of dependent node IDs.
None.
