HMIN_element_writemass()
Writes a mass element to the HyperMesh database.
void HMIN_element_writemass(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, double mass, HM_entityidtype systemid, HM_entityidtype nodes[], HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of mass, a user-defined value.
propertyid
The ID of the property assigned to the mass element.
mass
The mass of the element.
systemid
The system ID of the mass.
nodes[1]
The nodes associated with the element.
collectorid
The ID of the collector where the mass should be placed.
None.
