HMIN_element_writerbe3()
Writes an RBE3 element to HyperMesh.
void HMIN_element_writerrbe3(HM_entityidtype id, char elementtype, int Inode_len, HM_entityidtype *Inodes, int *Idofs, double *Icoeffs, HM_entityidtype Dnode, int Ddof, double Dcoeff, HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
Inode_len
The number of independent nodes.
Inodes
The IDs of the independent nodes.
Idofs
The degrees of freedom associated with the independent nodes.
Icoeffs
The coefficients associated with the independent nodes.
Dnode
The ID of the dependent node.
Ddof
The degrees of freedom associated with the dependent node (may be set to 0).
Dcoeff
The coefficients associated with the dependent node (may be set to 0).
collectorid
The collector where the RBE3 element should be placed.
None.
