HMIN_element_solver_writemass()
Writes a mass element with property idpool to the HyperMesh database.
void HMIN_element_solver_writemass(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, double mass, HM_entityidtype systemid, HM_entityidtype nodes[], HM_entityidtype collectorid, int propsidpool)
HyperMesh hminlib Function
id
ID of the element.
elementtype
The type of mass, a user-defined value.
propertyid
The ID of the property assigned to the mass element.
mass
The mass of the element.
SystemID
The system ID of the mass.
nodes[1]
The node associated with the element.
collectorid
The ID of the collector where the gap element should be placed.
propsidepool
ID pool number of the property to which the element should point.
None.
