HMIN_element_getnodesfromconfig()
Determines the number of nodes associated with the configuration of the element.
int HMIN_element_getnodesfromconfig(int config);
HyperMesh hminlib Function
config
The configuration of the element (HM_ELEMENT_CONFIG_TRIA3, HM_ELEMENT_CONFIG_QUAD4). For more element types, refer to the include file hmlib.h.
The number of nodes associated with the element. For rigid links and RBE3s, zero is returned because the number of nodes may vary.
None.
