HMIN_element_writebar3_vector()
Writes a 3-noded bar to HyperMesh using a vector to define the bar local x axis.
void HMIN_element_writebar_vector(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, double vector[3], double offseta[3], double offsetb[3], int pinsa, int pinsb, HM_entityidtype nodes[], HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
propertyid
The ID of the property to which the element should point.
vector[3]
The node at end a or end b of the desired vector.
offseta[3]
The amount to offset the bar at end a of the vector.
offsetb[3]
The amount to offset the bar at end b of the vector.
pinsa
The degrees of freedom assigned to end a of the vector.
pinsb
The degrees of freedom assigned to end b of the vector.
nodes[3]
The nodes associated with the element.
collectorid
The ID of the collector where the vector element should be placed.
None.
