Manufacturing Solutions
Metal Extrusion Tutorials
HX-0001: Importing Die Geometry
HX-0002: Create and Edit 3D Solids
HX-0003: Creating Die Geometry for Solid Profiles
HX-0004: How to Use the Project Browser
HX-0022: Mesh Generation for Solid Profiles
HX-0023: Mesh Generation for Hollow Profiles
Guidelines for Non-Hex Meshes
HX-0052: Bearing from Nodes
HX-0053: Define Bearing Profile from Control Lines
HX-0054: Bearing Creation from 3D Bearing Curve
HX-0100: HyperXtrude Analysis - Extrusion Wizard
HX-0101: Extrustion of a Solid Profile
HX-0102: Extrusion of a Solid Profile Die with Pockets
HX-0104: Modeling Dies with Symmetry Planes
HX-0105: Solid Profile Die with Multiple Exits
HX-0106: Indirect Extrusion - Solid Profile
HX-0107: Solid Profile Using Existing Mesh
HX-0108: Hollow Profile with Existing Mesh
HX-0109: Mesh Generation using Solid Map Option
HX-0151: Extrusion of a Hollow Profile
HX-0155: Indirect Extrusion of a Hollow Profile
HX-0201: Tool Deflection
HX-0302: Variable Time Step Analysis
HX-0303: Billet Skin Tracking
HX-0304: Transverse Weld Length
HX-0401: Select/Add New Material Properties
HX-0404: Fit Material
HX-0427: Add New Presses to the Database
HX-0452: Bearing Length Optimization using HyperXtrude and HyperStudy
HX-0500: Introduction to HyperView
HX-0501: Post-Processing
