Manufacturing Solutions
HX-0000: Introduction to HyperXtrude
HyperXtrude® is a finite element program that enables you to:
Analyze material flow and heat transfer problems in extrusion and rolling applications
Perform several analyses starting from a coarse mesh
Perform mesh refinements automatically
Solve problems commonly encountered in the metal and polymer extrusion industries where materials undergo plastic deformation
Solve both isothermal and non-isothermal flows
Handle several material models with robust solution algorithms
The process flow for a typical HyperXtrude run is shown in the diagram below:
The HyperXtrude Solution Process
HX_0000_01
HyperXtrude process flow
The HyperMesh Window
HX_0000_02
There are several main areas in the window:
Area
Title bar
The bar across the top of the interface is the title bar. It contains the version number you are running and the name of the current file.
Graphics area
The graphics area under the title bar is the display area for your model. You can interact with the model in three-dimensional space, in real time. In addition to viewing the model, entities can be selected interactively from the graphics area.
Menu bar
Located just under the title bar.  Like the drop down menus in many graphical user interface applications, these menus "drop down" a list of options when clicked.  Use these options to access different areas of functionality.
Toolbar
These buttons provide quick access to commonly used functions, such as changing display options.
Command Window
You can type HyperMesh commands directly into this text box and execute them instead of using the graphical user interface.
Utility Menu
This area contains macros and steps that guide the user to create HyperXtrude solver input files. Other macro pages also available and the content of the Utility Menu changes based upon the selected user profile.
Status bar
Any warning or error messages display in the status bar. Warning messages appear in green and error messages appear in red.
Panel menu
The panel menu displays for each page the functions available on that page. You access those functions by clicking on the button corresponding to the function you wish to use.
Utility Menu
The Utility menu allows you to customize the standard interface to include: buttons, radio options, and text that has HyperMesh-supplied and user-defined macros associated with it. The menu can be docked on either the left or right side of the graphics area.
A macro file controls the display and available operations of the Utility menu. Attributes that you can change include:
Page that displays the menu
Text to be displayed on the control
Location and size of the menu
Help message to be displayed on the menu bar
Macro to call, with optional arguments to pass
Using the Mouse
The mouse attached to your system is integral to HyperMesh and can be used in almost every aspect of user input. A two- or three-button mouse may be used.
The mouse buttons have these functions:
Button
Function
Left mouse button
Performs selection operations.
Right mouse button
Deselects entities in the graphics area.   Aborts graphics operations.
Middle mouse button
In the rotate (r) and arc dynamic motion (a) modes, selects a new center of rotation when you pick a node in the model.
CRTL + left mouse button
Dynamically rotates the model
CRTL + middle mouse button
Zooms into an area of the model
CRTL + right mouse button
Pans the model
You can also use CTRL + C and CTRL + V to copy and paste text and numeric information.
HyperXtrude User Profile
HyperMesh is designed to accommodate many different FE solvers. As a result, some panels may be too general for HyperXtrude users. By selecting the HyperXtrude user profile, you can work with pre-defined panels that are more specific to HyperXtrude usage.
Step 1: Load the HyperXtrude user profile
1.Select Start Menu > All Programs > Altair HyperWorks > Manufacturing Solutions > HyperXtrude to launch the HyperXtrude user interface.
2.The User Profiles dialog appears with Manufacturing Solutions as the default application. If it does not appear, you can access it from the menu bar by clicking Preferences > User Profiles.
3.Select HyperXtrude and Metal Extrusion.
4.Click OK.
HX_0000_03
HyperXtrude Utility Menu
The buttons in the Utility Menu fall into three categories: a) shortcuts to native HyperMesh panels, b) TK popup menus, and c) opens other macro panels.
Import Data
CAD
Import CAD drawing
HM
Import a HyperMesh file
HX
Import HyperXtrude mesh (*.grf file) and the parameter (*.hx) files with process parameters
Select Units
Set the units used in modeling the problem
2D Elems
Control 2D element display
3D Elems
Control 3D element display
BCs
Control display of loads
Lines
Control display of lines
Surfs
Control display of surfaces
Clear Temp Nodes
Remove all temporary nodes
Extrusion Wizard
Process automation tool to help create HyperXtrude analysis files
Material Data
Select materials from material database and assign material properties to different components. You can also view Viscosity/Flow stress graph for a material
Boundary Conditions
Create/Edit BC
Define and assign boundary conditions on element faces
Check Undefined BC
Check for the element faces without any loads defined for them
Check Duplicate BC
Identify element faces with duplicate loads
Update 7.0 BC
Read old data files created for HyperXtrude 7.0 and converts boundary conditions to native HyperMesh format
Process Data
Specify run control parameters
Extract Points
Define solution monitoring points in the mesh
Model Summary
Displays a summary of number and types of elements in the model
Export Data
HX
Create HyperXtrude data files
Save HM
Save the data in HyperMesh format
Launch Solver
Launch the HX Solver using the current model, using the data deck or using a restart file
Step 2: Retrieve a HyperMesh Database File
The model files for this tutorial are located in the file mfs-1.zip in the subdirectory \hx\MetalExtrusion\. See Accessing Model Files.
To work on this tutorial, it is recommended that you copy this folder to your local hard drive where you store your HyperXtrude data, for example, “C:\Users\HyperXtrude\” on a Windows machine. This will enable you to edit and modify these files without affecting the original data. In addition, it is best to keep the data on a local disk attached to the machine to improve the I/O performance of the software.
1.From the File menu, click Open.
2.Browse to the file HX_0000.hm.
3.Click Open.
Step 3: Save Your Work as a HyperMesh Binary Database
1.From the File menu, click Save As.
2.Type the file name in the file browser. Make sure to give it a .hm file extension.
3.Click Save.
Return to HyperXtrude Tutorials
