Learn how to access and download required tutorial files.
Required model files are available on the Altair Connect site and in the Marketplace on Altair One.
| 1. | Go to Altair Connect. If documentation is installed locally, you can find model files as follows: |
Windows example: C:\Program Files\Altair\<version>\tutorials
Linux example: \<version>\Altair\tutorials
| 2. | If required, enter your username and password. |
Note: Model files are also available in the Marketplace on Altair One at https://altairone.com/. If logging into Altair Connect or Altair One for the first time, click Need help signing in? to create an account, and follow the instructions on the Altair One site.
| 3. | Select the suite version from the list, then on the Documentation tab, scroll to find the Tutorial File section and select the desired tutorial model file(s) to download. |
Note: The files may require unzipping before proceeding with the tutorials. When extracting zipped files, preserve any directory structure included in the file package.
