Manufacturing Solutions
HX-0001: Importing Die Geometry
Previous topic Next topic Expand/collapse all hidden text
Geometry can be imported from many sources.  The files can come from various programs and in different formats.  Sometimes even a single format may have variations.  Because of all these factors, surfaces of imported parts might not be properly connected.  A number of functions rely on having surfaces properly connected, especially the Automesh panel.  This section guides you through using various geometry cleanup tools to restore proper surface connectivity to part geometry.
In this tutorial, you will:
Delete untrimmed surfaces
Close missing surfaces
Set the cleanup tolerance
Equivalence free edges
Delete duplicate surfaces
The benefits of importing and repairing CAD are:
Correct any errors in the imported geometry
Create the simplified part needed for the analysis
Mesh a part all at once
Ensure proper connectivity of mesh
Obtain a desirable mesh pattern and quality
Importing and Repairing CAD Geometry Data
The model files for this tutorial are located in the file mfs-1.zip in the subdirectory \hx\MetalExtrusion\HX_0001. See Accessing Model Files.
To work on this tutorial, it is recommended that you copy this folder to your local hard drive where you store your HyperXtrude data, for example, “C:\Users\HyperXtrude\” on a Windows machine. This will enable you to edit and modify these files without affecting the original data. In addition, it is best to keep the data on a local disk attached to the machine to improve the I/O performance of the software.
hmtoggle_plus1greyStep 1: Load the HyperXtrude user profile
1.Select Start Menu > All Programs > Altair HyperWorks > Manufacturing Solutions > HyperXtrude to launch the HyperXtrude user interface. The User Profiles dialog appears with Manufacturing Solutions as the default application.
2.Select HyperXtrude and Metal Extrusion.
3.Click OK.
HX_0000_03
hmtoggle_plus1greyStep 2: Import the IGES geometry file into the current session
1.Access the Import tab in one of the following ways:
Click File > Import.
Click the icon fileImport-24.
2.Click the Geometry icon fileImportGeometry-24 to set the Import File Type to geometry.
3.Set the File Type field to Auto Detect and click Select Files fileOpen-24.
4.Select the file: HX_0001.igs
5.Click Import to read the die geometry.
6.Click Close to close the Import tab.
7.Take a few moments to observe the model using the different visual options available (rotation, zooming, etc.).
HX_0001_01
hmtoggle_plus1greyStep 3:  View the model to evaluate its integrity
1.Observe where the model has incorrect connectivity and missing or duplicate surfaces.
2.From the main panel, click edge edit.
3.Note that the surface edges are now colored according to their topology status. This occurs because the Geometry Color option visualizationGeometryColorMode-24 Auto is set to Auto.
4.Click the Wireframe Geometry icon visualizationGeometryWireframe-24 and the Shaded Geometry & Surface Edges visualizationGeometryShadedWithEdges-24 icon to explore the different display modes.
5.The toolbar contains icons that control the display of the surfaces and surface edges. Surfaces can be shaded with or without edges, or wireframe. Right-click the icons to access the drop down menu for additional options. Place your mouse over the cursor to view a description of the button’s functionality.
6.Set the display mode back to Wireframe Geometry visualizationGeometryWireframe-24.
7.Click the Visualization icon visualization-24 and select the Topology icon topology_icon.
Visualization controls the display of the surfaces and surface edges. Surfaces can be shaded or wireframe. The check boxes within this menu turn the display of the different edge types and fixed points (surface vertices) on or off.
8.Clear all the check boxes except the Free check box.
Only the free edges should be displayed.
HX_0001_01a
9.Observe the free edges and make a mental note of where they are. The free (red) edges show where there is incorrect connectivity or gaps.
10.Note the locations where there are closed loops of free edges.  These are locations that probably have missing surfaces or are not equivalenced.
11.In the Visualization tab, select only the Non-manifold edges check box. Observe the non-manifold edges and make a mental note of where they are.
HX_0001_02
Free edges indicating surface discontinuities of the die cavity.
The non-manifold edges show where there are more than two surfaces sharing an edge, which might be incorrect connectivity.  For this part, there are yellow edges surrounding two areas.  This tells us there are possible duplicate surfaces in these locations.
12.In the Visualization tab, select all the check boxes.
13.Click the Shaded Geometry & Surface Edges visualizationGeometryShadedWithEdges-24 icon. The surfaces should now appear solid rather than having only their edges displayed.
14.Rotate, zoom, and pan to locate any errors in the geometry.
15.Make a mental note of the areas to be worked on. You find:
An untrimmed surface
Multiple missing surfaces around weld chamber
HX_0001_03
Untrimmed surface and multiple missing surfaces
16.Click the Wireframe Geometry icon visualizationGeometryWireframe-24 to change back to wireframe display.
17.Click return to close the panel.
hmtoggle_plus1greyStep 4:  Delete the surface that overhangs the round corner
1.From the main panel, click Delete.
2.Change the entity selector to surfs.
HX_0001_03a
3.Select the untrimmed surface shown in the previous figure.
4.Click delete entity.
5.Click return.
hmtoggle_plus1greyStep 5:  Combine multiple free edge pairs at one time with the equivalence tool
1.From the toolbar, change the Geometry Color Mode to By Topo visualizationGeometryColorMode-24BY TOPO.
In Topology color mode, each color represents different topological mode:
Free edge (red color): The edge is owned by one surface. On a clean model, free edges appear only along the outer perimeter of the part and internal holes. Free edges that appear between two adjacent surfaces indicate the existence of a gap between the two surfaces.
Shared edge (green color): The edge is owned by two adjacent surfaces.  When the edges between two adjacent surfaces are shared (green), there is no gap or overlap between the two surfaces, and they are geometrically continuous. The automesher always places seed nodes along their length and will produce a continuous mesh without any gaps along that edge.  The automesher will not construct any individual elements that cross over a shared edge.
Suppressed edge (Blue color): The edge is owned and shared by two adjacent surfaces but it is ignored by the automesher.  They are blue dotted lines by default. Like a shared edge, a suppressed edge indicates geometric continuity between two surfaces but, unlike a shared edge, the automesher will mesh across a suppressed edge as if was not even there.  The automesher does not place seed nodes along their length and, consequently, individual elements will span across it.  By suppressing undesirable edges you are effectively combining surfaces into larger logical meshable regions.
Non-manifold edge (Yellow color): The edge is owned by three or more surfaces. They typically occur at "T" intersections between surfaces or when 2 or more duplicate surfaces exist. The automesher always places seed nodes along their length and will produce a continuous mesh without any gaps along that edge. The automesher will not construct any individual elements that cross over a nonmanifold edge.  These edges cannot be suppressed and can sometimes be indication for duplicated geometry.
2.Open the Edge Edit panel.
3.Open the equivalence subpanel.
4.Select surfs and from the extended selection menu, select all.
5.Ensure that the equiv across comps option is check marked ON.  This will ensure that equivalencing of the surface edges between different components will be performed.
6.Ensure that the equiv free edges only option is check marked OFF. Turning this option OFF will ensure that equivalencing between shared edges will be performed helping to identify potential Non-manifold edges (yellow edges).
7.Click the green equivalence button to combine any edge pairs within the specified cleanup tolerance.
HX_0001_03b
Most of the red free edges are combined into green shared edges. The few remaining are caused by gaps larger than the cleanup tolerance.
8.Click return to close the panel.
hmtoggle_plus1greyStep 6:  Find and delete all duplicate surfaces
1.Open the Defeature panel.
2.Open the duplicates subpanel.
3.Click surfaces >> displayed.
4.In the cleanup tol = field, type 0.20.
5.Click find. The status bar displays the following message, "2 surfaces are duplicated".
6.Click delete to remove any duplicate surfaces.
hmtoggle_plus1greyStep 7:  Create surfaces to fill large gaps in the model
1.Open the Surfaces panel.
2.Click the spline/filler spline_filler_iconicon.
3.Deselect the keep tangency check box.
The keep tangency option looks at surfaces attached to the selected edges and tries to create a surface tangent to them.  This helps to form a smooth transition to the surrounding surfaces.
4.Ensure the entity type is set to lines.
5.Ensure the auto create (free edges only) check box is selected.
The auto create option simplifies the selection of the lines bounding the missing surface. Once a line is selected, HyperMesh automatically selects the remaining free edges that form a closed loop, and then create the filler surface.
6.Zoom into the area indicated in the following image.
HX_0001_04
7.Pick one of the red lines bounding one of the holes. HyperMesh automatically creates a filler surface to close the hole.
8.Repeat step 7 to create filler surface in the all gaps around the model.
9.Click return.
hmtoggle_plus1greyStep 8:  Observe the model again to identify any remaining free edges, or missing or duplicate surfaces
Use the topology display and shaded modes to perform this task.  All of the edges in the model should be displayed as green shared edges, indicating that we have a completely enclosed thin solid part.
Click return to go to the main menu.
hmtoggle_plus1greyStep 9 (Optional):  Save your work
Once the cleanup operations are completed, save the model.
Return to Metal Extrusion Tutorials
